Doing the 2391 soon, and have a question about the test !
There is a submain board, which is fed by a 100A 30ma RCD (i believe), and understand that, i will do a Zs on this - as it is a circuit fed by the 3 phase board.
I will then make sure the main switch, in this case the 100A 30mA RCD is turned off, remove the earthing conductor, connect one lead to this, and then the other to the incoming side of the main's live terminal, in order to perform the test for Ze ?
How would i perform the RCD test on this, would i connect one lead to the Earth Terminal, and then the other 2 leads to the outgoing side of the RCD, how will i connect to the live ???
Could someone try to help clear this up please ! Thanks
