If it is simple fault then why after talking to various people and having people look at the computer and even suggesting faults then why after 3 months after i moved in have I not got a working computer in my flat. An electrician check the continuity on the flat yesterday from the consumer board. He did a few checks and found a loose connection on a kitchen light switch which was scorched and he changed that
but said it would have nothing to do with my computer problem as it was on a different circuit. Apart from that he found nothing wrong. That said after he left we went out came back in switched on the hall lights and they flickered like mad and flickered when I pressed the hall light switch. I then turned it off then on again a few times now it is seems to be working ok, so that was a bit weird. I am having the electric supplier check the supply from the street into the house so if that is ok I will get another computer because i took the new one back as it was under warranty, but why have i got the feeling that the same thing might happen again even with a surge protector???
Any comments would be very much appreciated.
