2nd Outside Light
24 Feb 2007
Leicestershire
I have recently fitted a 150w outside spot to light up the garden.
I took the feed from a double socket using a fused spur switch. I know need to fit a 2nd outside light near my back door.
Can I use the same spurred switch to attach a 2nd light or do I need a separate spur from another socket?
regards. Pat
It will be fine to use the existing. Id take the cable out of the fitting into an IP rated enclosure using stuffing glands and run the cable from this to both lights each having a separte cable into the enclosure.
Thanks for the quick reply and it was you who helped me out fitting the light last week, many thanks for your help and advise.
So now I can use the spurred switch that saves a lot of work.
The new light I want to fit is only about 2 or 3 metres away from the spurred switch and where the cable comes out of the wall and the spot light is all the way around the other side of the house.
Can I take another cable from the fused switch to the light that would be 2 or 3 metres away or do I need to fit a box like you said?
Or cut the cable (that supplies the flood light) nearer my proposed light and add a box then only need 2 or 3 metres of cable from that junction box to my new light near my back door?
Many Thanks Again. Pat
Well most of these 150w floodlights only have one cable entry so thats why i sugested the enclosure as a joint box. But if the light you are installing has two cable entrys then it would be fine to run the cable in then out to the next.
Not sure what you are calling a "fused switch"
Providing the current rating of each of the two cables, exeeds the fuse size, ie 5amp fuse.
Connecting two cables into the "fused switch" should be ok.
Providing the"fused switch" is suitable for the purpose and not the Switched FCU type designed for ONE FLEX outlet
OK this is the light switch that I have connected to a double socket:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320215445137
This is connected to a 150w outside light with one inlet for the cable.
I want to connect an outside light near my back door. The cable from the above switch comes out from the wall about 2-3 metres away from my proposed light, then leads away about 10 metres to the back of the house.
If I take a cable from the 150W light all the way back to my proposed light that just seems a long way.
So what I really need to know is:
A: Can I take a 2nd cable through the wall 2-3 metres to the proposed light near my back door from the above switch?
OR
B: Can I split the cable near where it comes out of the wall and add an IP rated box with 2-3 metres of cable to my proposed light near my back door and then add the cable to my already fitted 150w light around the back to the box?
Sorry to be a pain but its always harder to explain the positions and things than to actually due it. I know what I mean even if I don't know if its right !! I know that by using a single witch both lights will be on at the same time but this is not a problem.
Many Thanks For Everyone's Help & Patients. Pat
