Thats why I said see if it self seals in a couple of days, it happened on one of my sons radsNot usually
Yeah, to be fair I think I only wrapped the tape around 5 times. I've looked at the ice cream carton this morning and there's a very small amount of water in there maybe 5 drops or so. I can still see tape on the exposed threads so maybe I'll get away with tightening it up a tad more just don't want to over tighten and strip the thread.Yes, but it's good practice! - to get accustomed to that sort of activity - once you've done it once or twice its no longer a big thing. Hopefully you put plenty of ptfe wraps on the tail. If you do have to remove the tail then it's best to rewrap the threads. Do look on youtube for best way to wrap the tails-some useful stuff there.
Surely when I remove the tail from the rad water will start pouring out?, or with a combi is there enough presure to cause a vacuum so not much water escapes, so I have time to remove the old PTFE tap and applied new before I'm drowning in water??If there is enough play on the pipework to allow you to remove the tail with the valve still in position ,you don't need to drain down. If you do drain down top up inhibitor.
6. Re-wrap with PTFE (15 wraps) winding in the direction that it won't unravel when you screw tail in.
Clockwise with the end of the tail towards you. That way tightening pulls the tape into the thread, ACW would push it out.This is actually a good point and something I never considered.
So the tail will screw into the rad clockwise right as the thread is on the tail itself, so do I need to apply the tape to the tail counter-clockwise or clockwise?
If you hold the smooth part of the tail in your left hand with the thread to the right then turn the tape onto the thread away from you - ACWdo I need to apply the tape to the tail counter-clockwise or clockwise
ACW ? Anti clockwise ?If you hold the smooth part of the tail in your left hand with the thread to the right then turn the tape onto the thread away from you - ACW
Hold the tape roll so it unwinds around the threads backhanded from the bottom of the roll.
Yup .... as it goes on the thread, it goes on away from you if you hold the tail with the thread on the right, that's, so when the tail is tightened in CW it's tightening against the tape.ACW ? Anti clockwise ?
You sure about that
With the threaded end facing you, the way you'd normally hold it (as I said in #22), that looks like clockwise to me. But your pic should make it clear to the OP.Yup .... as it goes on the thread, it goes on away from you if you hold the tail with the thread on the right, that's, so when the tail is tightened in CW it's tightening against the tape.
Depends on what end you are looking at it from though. I'm right handed so I hold in my left and wrap with my right, as I look at it to me that's ACW.
edited to add pic
Sorry but I just wouldn't hold nor ever look at it like that, hence my description. Held in my left hand with the threads to the right or right hand with the threads to the left, the tape would be going on ACW. If the tail then turns and tightens into the rad clockwise then the tape would still be running anticlockwise to ensure it doesn't unravel.the way you'd normally hold it
OK, as long as the OP understandsSorry but I just wouldn't hold nor ever look at it like that, hence my description. Held in my left hand with the threads to the right or right hand with the threads to the left, the tape would be going on ACW. If the tail then turns and tightens into the rad clockwise then the tape would still be running anticlockwise to ensure it doesn't unravel.
The only time it would clockwise is looking at it head on at the thread end, which is always an option and all are correct depending on the view/opinion I guess.
Hang on, thats wrapping it CW based off that picture then no? As you wrapping it away from your body not towards??. Imagine turning the tail so the thread is now facing you you'd go around with tape CWView attachment 296406
edited to add pic
