Yep I want to do it right but I need to make sure Im doing it right and safe.
Before I made any changes I noted where everything went and found out which cables supplied which lights and the main reason for my work is because I was fitting loft insulation to the area where the wires was and I read you cant put any insulation over any cables so I started work in moving the junction box to a non insulated area under the floor which will always be accessable in future.
When I first looked there was old types of wires like old flex going to one light so I replaced that with my 3 core and earth.
Also as I have mention before in other posts my upstairs lighting circuit dont have any earths so I can fit the fancy metal light fittings but the main supply for the junction box does have an earth cable fitted does this meen if I run new cables to the light points I can have metal lights?
How can I check if the earth is connected at the junction box end?
Thanks for your replys and patience so far.
