I want to add 2 wireless rear speakers to my 5.1 surround system. I have found a piece of kit that sends/receives the audio signal, and powers the rear speakers. The unit uses 1 amp at 24v so about 24watts of power.
Now I have a concealed cubby in the rear of my living room ceiling which houses an LED strip power supply and in there is the lighting circuit. I would therefore like to add a 3amp fused spur to a single regular 3 pin plug to power the speaker receivers.
Having overseen and helped designed the lighting circuits with my electrician a while back I know that all the cable is 1.5mm covering the living, dining and kitchen only and being received by a 6amp RCBO. That RCBO does cover 2 floors, but each floor has its own 1.5mm radial lighting circuit. All the lights are bulb-less LED spots and there is one kitchen extractor running off the circuit (which will move to the ring when I redo the kitchen) - so the draw on the circuit at peak usage is still very low.
I am therefore 99.9% happy that the draw from the speakers is low enough to keep well within the tolerance of the wire, and that both the 3amp fused spur and 6amp RCBO are sufficient to protect the cabling from someone in the future plugging something large into the socket (which is unlikely as it will be hidden in a ceiling void
. To me this seems similar to adding a 3 pin socket to the lighting circuit for a TV amp in the attic.
Are there any other issues that I need to consider? I am really just looking for that additional 0.1% confidence that I have not forgotten anything.
Thanks,
Jon
PS - I also believe that this is non-notifiable as it is a fused spur to a radial circuit.
Thanks,
Jon
