3 port valves
23 Aug 2008
Essex
Hi all, I installed my own central heating about 24 years ago, never done it before, worked great right away and still is. One problem 3 port valve I am on about my 3rd or 4th valve in them years, every thing works fine but after a few years when it is getting to winter on goes the heating side and the valve sticks. It's really annoying any Idea's please. Thanks.
Hi, we put the heating on the water is of, then when we turn the heating off the leaver in the valve stick and the valve buzzes.
When you change the 3 port valve do you check the valve that it is driving? in my experience if this gets tight it eats the motor. Change the actuator part if it's tight, if it's a later Honeywell you can change just that part rather than the complete assembly
Hi Jajodu, just check that all OK but good idea. I have taken the cover off temporarily to see just what is happening. Cheers
I'd still take a good look at the rubber ball valve , you would need to drain down to that point though.
Hi D_Hailsham, haven't tried turning the hot water on & off again yet.
Hi Jajodu, where is rubber ball valve??
Remove the three port head, underneath it is the valve, you need to remove the screws and lift it out. Drain down first!
