3 problems and havn't got a clue =30ci glowworm boiler help.
10 Mar 2012
Clwyd
hi all
new to this forum and hoping for some help
i have a 30ci glowworm boiler, i have an overflow problem (water coming out) a tap/dripping noise in the pipes, and my combi shower water is only running cool, hoping these are not very big problems :?
thanks in advance, any help would be very much appreciated
:D
Impossible to say would need more info ie where is water leaking etc, what's the pressure of system water in boiler, any fault codes ie f22 etc
Sounds like you have a number of problems.
Expansion vessel and PRV need attention
Plate heat exchanger is blocked or diverter guffed.
Water dripping noise? cant help with that one
I'd get someone in if i were you.
the water is coming out of the overflow pipe outside, think i need a plumber asap
thanks for help
:D
oh and no fault codes, and water pressure is 1 bar, any lower and system goes off
