32mm waste pipe inspection port
13 Feb 2025
Am looking to fit 32mm grey water (sinks/showers/taps/washing machine) inspection ports (in line with screw cap) allowing me to put a wet vac or a long wire inside and clean the gunk out. Don't know what it's called. Anyone know?
If you want to have a rodding point on the run - if it's for a sink/shower/bath - then that will typically use 40mm waste pipe. If you want to use a 32mm rodding access then you'll need a 40mm Y piece and then a reducer on the rodding point leg for the 32mm rodding eye to fit into.
Can I also suggest, depending on what pipe is there already, that Aquaflow (TS) may not be the best choice for the fittings. For some strange reason they seem to have a slightly different ID size and don't seem to match with the other standard makers pipe and fittings, you may find it difficult to get Aquaflow to be a good fit on other makes of pipe.
I believe FloPlast do a 40mm 135Deg branch and will happily fit standard 40mm pipe
Good call, keep forgetting there are some rogue fitting about now, Solvent used to be standard across the Manufacturers. I used the TS link as wasn't sure if the Screwfix page would give all my details away!
Absolutely, I'm at a loss as to what Aquaflow are up to and why TS stock it. The only reason I can think of is to ensure that only their products can be used together/interchanged. It doesn't make sense though as I'm sure their products would be used more often if they were interchangeable with other brands.
On Screwfix delete anything after the ? mark at the end of the product number. All the stuff to the right is, for example, data related to how you found the site via a search engine
vs the version with extra stuff stripped out
