I have been a bit naughty and installed a couple of fans with out 3amp protection, am I right in saying that if the manufacture doesn't specify a 3amp protect then it isn't needed? I've need seen it required before in the fans I normally install.
The ones I have installed and been pulled up on (NIC inspection) where cheap newlec's and they do state a3amp fuse (who knew).
Surly a 6amp mcb will trip before a 3amp fuse any way.
I have two options
1.replace the fan for a decent one
2.3amp mcb in DB
What would you do??
I have two options
2.3amp mcb in DB
What would you do??
