Hi, I know this is notifiable, but friend's brother is gonna do this [edit: in his house] anyway, so we might as well get it right.
Please don't advise on wiring from the CU to outlet - I know how to calculate and check all that, it's just the last bit that puzzles me.
Beko recommends the cooker be wired to the cooker connection plate in H05W-Fg 5 x 1.5mm2 cable or 3 x 4mm2 "or equivalent".
Sure, it's a 9.4kW total consumption, so we could use diversity to get 20.3A requirement [based on 230V which is how I assume I should do it?] (?).
Since the cooker has only 3 terminals (L+N+CPC), I can't see why you'd bother using 5-core. To double up the L+N perhaps? Still that only gives us 20A current capacity (not sure about that figure tbh).
Wouldn't it be better just wired in a bit of 6mm T+E, even though that's not ,technically, flexible?
Surely the reference to 5 core 1.5mm2 is a typo? Would anyone here consider using something that thin (especially given the probable warm environment), even though there would be two live and two neutral cores?
