I am fitting an outside light (500w halogen) that will have a switch in the kitchen to control it. I was intending to use the JB method to wire it up and instead of using 1.0mm lighting cable I am intending to use 1.5mm (just from the JB to the light not as the switch cable). I have 6 x 60w lights on this circuit, 1 350w outside halogen and a couple of switch operated wall lights. The fuse box (RCD and only 3 years old) has a what I believe to be a 6A fuse in it.
Is this too much for this circuit? Do I need a different fuse?
