I am currently upgrading the system in my house
It currently uses a Gas tankless water heater which provides around 35L/min
I would like to add a Central Heating system for 3 floors with weather compensation.I would like to use a Indirect Vented Combination Cylinder as a Buffer, to act like a combination boiler with a Gas Saver to improve economy. Was looking to use a Danfoss Controller to control temp,zones and pump.
I have come up with a design :
http://tinypic.com/r/fk1f9x/6
I cannot add a accumulator as the way the loft is designed with hatch opening, its impossible to get tanks upstairs and no space on the lower levels.
As I also need to change the mains from lead to MDPE. I was going to run a 50mm MPDE to compensate the flow rate which is currently 12L/Min and I would rather oversize then under size as in the future I may add more to the house, currently running 2 weak showers and a slow filling bath. Thames water have told me that they will make the connection as I am replacing the existing lead pipe. I was wondering what is the best quality connections for inside the house.
I was going to go from 50mm MDPE X 42mm Copper and then T to make 22mm to the gas heater and 22mm for the rest of the house. But I cannot find a stop tap for 50mm poly x 42mm copper. I have found plastic stop taps but my confidence in them isn't that great
Any help or Advice would be much appreciated.
