777 down.
Status
Not open for further replies.
My God! 17 pages on that ... People MUST have been bored stupid at the time :lol:
Answer is ... Yes, of course the aircraft would take off.
MW
what, with an airspeed over the wing of zero?
The aircraft will take off as normal, the wheels will spin at whatever speed they need to, for this to happen.
The aircraft gets its thrust from the air not the ground.
Remember the wheels are not driven.
Trazor is correct, the wheels have nothing to do with this and are only there to support the aircraft whilst its on the ground :lol:
Engines produce thrust, aircraft moves forward and once there is sufficient airflow across the wings the aircraft is airborne.
Doesn't matter whether the aircraft is on wheels, skids or dragging along on its belly (assuming there is enough thrust to overcome the drag).
MW
The plane won't take off because the reverse speed of the conveyor belt automatically matches the forward speed of the plane.
This conveyor belt has a control system that tracks the aircraft's wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction.
So the plane rolls forward relative to the belt, but the belt moves the plane backwards by the same amount and the plane remains stationary relative to the air.
Go away and think about what you've just posted :lol:
If you want to try something out ... Take a model aircraft with you next time you go shopping and try it on the conveyor.
Irrespective of how fast the conveyor moves towards you the plane will still move forward at the speed you push it.
Different scenario if you put the brakes on though but we must assume that the brakes are off for takeoff :wink:
This could only happen if the brakes are on.
MW
MW
I have thought about it.
Someone posted in the other thread 'Wheels or no wheels a force is pushing the friggin thing forward' Making the mistaken assumption that there is nothing pushing back. Like rolling resistance which will increase with the rotational speed of the wheels.
It is a good site Empip though it does over simplify many things which creates inaccuracies for the purist :wink:
One such instance is ...
This densely packed air/fuel mixture is ignited and the resultant "explosion" accelerates the gases out the rear of the engine at a very high rate of speed.
There is, in fact, no "explosion" in a gas turbine, the air/fuel mixture is simply ignited and held as a constant flame on the burner ring within the combustion chamber ... The more fuel you add, the more heat (and thus energy) is produced which spins the turbine(s) faster producing more thrust at the fan which is connected at the other end of the LP spool shaft.
Artistic licence though by the authors to put the point across and doesn't diminish from the site at all.
Hmmmmnnnn I'm hoping you're just having a laugh now, or perhaps you're ****ed :lol:
If you are serious I suggest you set up a simple experiment to investigate as I've suggested as, I can assure you, the aircraft will take off as normal and the pilot wouldn't notice any difference. The only physical difference will be the wheel rotational speed which will be the sum of the normal speed plus the speed generated by the conveyor.
MW
I always thought that a "combustion chamber" is where the fuel/air mixture usually highly compressed is ignited and explodes, in a normal combustion engine this force is used to push a piston, in the gas turbine the hot expanded gas forces its way out the back of the turbine, via other blades that in turn drive the front fan also which helps suck more air in to continue the cycle.
MW
That's the Navy bolloxed with the Aircraft carriers then
MW
Isnt that adding another problem to the equation, dont they go up and down aswell with the waves :wink:
Status
