85mm drywall screws
7 Dec 2006
Cheshire
Could anyone point me in the right direction of a supplier of 85mm or 90mm drywall screws for fixing insulated plasterboard to 25mm battens Thanks
Sorry I forgot to mention that I have tried usual sources including screwfix and local builders merchants, 100mm are to long they would hit the brickwork (can i use any other screws, or do they cause problems when skimmed over)
90mm of insulation and plasterboard with a fixing of only a nominal 20mm :shock:
I know this reply might be a bit late for the OP (I hope it is) :)
But I thought I would add this reply in case anyone else is in a similar situation & comes across this thread, just like I did.
Best screws I have managed to find are the Timberdeck 4.0 x 85mm decking screws from Screwfix.
I have just purchased a sample box & they seem ideal not much thicker that a proper drywall screw, I just hope the coating on them will be OK with the plaster.
