8mm Rad Valves?
21 Aug 2003
I need to source a pair of 8mm / 1/2" in-line radiator valves. Not bothered if they are Thermostatic or standard. But I'm struggling! Does anyone know if they are actually available?
Thanks in advance.
8mm in-line might be a problem, but you could always use 15mm in-line and fit reducing bush to 8mm. Are you sure you can't use an angled valve? Try BES.
You can always use a 15mm valve with a "reducing set", which replaces the 15mm olive.
