A few questions
21 Mar 2008
Wolverhampton
I am refitting my bathroom and am about to start the tiling. I have read the sticky, which is very good and clear (thanks gcol) but have a few questions to clarify a couple of points
1. Bath is fixed to the wall and I intend to seal it with silicone, level with the top of the bath. I have a dunlop tanking kit and was going to paint this so that it just meets the silicone. Is this ok or should I use some of the matting at this point ?
2. If the bath is level, can I tile from this (leaving a small gap for sealing) or is it preferable to fix a batten one tile's height up and work from there, fixing the bottom row of tiles last ?
3. I have constructed a studded wall at one end to house the shower valve. Is it best to tile the wall and then drill the necessary holes for this, or fit the valve and then tile around?
4. The studded wall is faced with 12.5mm plasterboard, (to be tanked). Which is the best of the BAL powdered adhesives to use on this and will this also be OK on the other brick and plastered walls.
Many Thanks for your help.
Make sure that your silicone seal is not higher than the bath top. Then use the matting and push it into the joint ensuring that it sticks to the edge of the bath. Then paint the tanking solution over it and the walls.
Tiling from the bath is fine. Have you made sure that you won't be left with a thin cut at the ceiling? (If you're tiling to the ceiling that is.)
You would normally drill the holes in the tiles to go around the water pipes before sticking the tiles up. Then fit the valve to the tiles.
Bal Single Part Flexible Adhesive will be just fine. http://www.trades-direct.co.uk/modules/shop/view.asp?Prodcode=2025-104
However, if your tiles aren't too big, you might find using Bal White Star a bit easier as it's pre-mixed. http://www.trades-direct.co.uk/modules/shop/view.asp?Prodcode=2190-101
