- Joined
- 14 Jul 2007
- Messages
- 18
- Reaction score
- 0
- Country
hi all
i need a bit of advice. could someone help answer some of these questions please
1. if you have the 17th edition and are part p are you only allowed to sign off your own work. and if you want to sign off someone elses work, or do periodic inspections on domestic properties do you need another qualification.
2. could someone recommend an easy, simple to understand dvd or book that explains step by step the procedure and how to carry out initial verification and testing
i have seen these 2 dvds they have differnt covers but are they the same dvd?
http://www.niceicdirect.com/catalog/partdetail.aspx?partno=DVD1
http://www.voltimum.co.uk/news/1107...-testing-dvd-helps-domestic-electricians.html
3. would it be possible to setup up a test rig on a piece of mdf/chipboard so i could practise testing, if this is possible are there any possible problems or limitations in this method, also if i wanted to carry out live testing on this rig how would i power it up, would i plug it into a 13a socket via a plug and use the other ends in the consumer unit on the test rig
many thanks for all your help.
