About Installing Electric Shower Please Help!
No, you can't.
The cable is not large enough to supply the shower, you will need to get the electrician to install a new circuit, and advisably do a PIR looking at that 'round gadget' wiring (its a jb btw).
Do you not think that the electrician would have done what you are suggesting if it were possible?
Do you have a bath?
No, you can't.
Thank you very much, I will just ignore this cable. Thank you!
What boiler do you have?
If it's a combi, you shouldn't need to pump it.
If you have a normal hot water cylinder, you should be able to add a pump to this for your shower.
Thank you for your help. My boiler is conventional one. Unfortunately, my water tank is Elson, so I can't put any pump... Thank you again!
