Hi
Hoping someone can help... I recently installed a new speed sensor (front passenger) on a 2011 infiniti M30D. I had to drill the old one out so its in bits. Only problem is I'm still getting an ABS sensor error. If I clear the codes using an OBD2 then the light stays off for about 100 metres then comes back on. What ive noticed is if I choose live data on the OBD2 all the speed sensors give roughly the same speed, including the front passenger. But for some reason it will randomly drop from say 40MPH to 25MPH only for a split second but that seems to be enough to cause the error. Anyone have any ideas why its doing this, like i said i did drill the old one out so could it be that Ive damaged the hub
Thanks for any help
Mike
Thanks for any help
Mike
