accenta g3 mini alarm system
8 May 2012
Birmingham
hi have extended a pir cable on this system and now none of the pir's on the system work how can i fix it? please help many thanks mike
You will have popped a fuse in the main control box , is the system under a service maintenance contract .
:( the systems not under any contract original engineer is no longer around any idea what size fuse etc so i can get some before i go round many thanks
1 amp , quick blow , ebay is your friend - Obviously not to some
If you decide to do it yourself , be carful in the main panel as 240 v is prenent near the transformer in the bottom right , check the fuse
thanks very much i will proceed with caution
new fuse fitted all pir's working except for 1, now system won't set keeps showing zone fault on that zone any ideas?
Have you checked the wiring for continuity , nicks , and shorts?
and or closed the tamper loop and wired correctly?
