Hi, finally managed do get back to this, power failure and lockdown delayed things. Hope you are sitting comfortably
Connected upstairs RKP with short lead to panel and left downstairs connected worked ok backlight went on both out RKPs.
Connected downstairs RKP to upstairs wiring and into panel with the short lead RKP also connected upstairs did not go out.
Connected both RKPs to panel with short leads to panel backlight went out when used to reset the other did not, powered down then up used
other RKP to reset, backlight went out the other did not, pressed a key on the second RKP backlight went out.
Do not understand it, so rewired both RKPs to original wiring, powered up reset using downstairs RKP backlight went out then pressed a key on upstairs RKP backlight goes out, now each RKP backlight goes out after use.
Now got another problem on selecting walk test zones 7&8 have '1' underneath with rapid bleeping others are '0', there is nothing connected to them as I am only using 1-6. Have factory reset a few times but it does not change this.
Again any suggestions
