    Dismiss Notice
Access after installing first floor joists and boards
Discussion in 'Floors, Stairs and Lofts' started by acurachris, 7 May 2019.
  1. acurachris
    acurachris
    19 Jan 2006
    301
    Thanks Received:
    58
    Manchester
    Country:
    Hi
    I am going to be installing the first floor joists and boards on my house extension and have a question about access! :unsure:
    After the joists are installed I intended to install the floor t&g boards on top which is all great, although how would I gain access to my new floor when it's complete to finish the internal walls? Is it normally accessed off the scaffold or from a floor board left out in the floor (hole)?
    Leaving a board out would work but means I can't permanently glue and fix the floor at this stage.
    Access from the scaffold works although at varying points the height differences in the scaffold to floor are going to be awkward.
    What's normally done? I realise this may be an obvious answer to some (not to me though!) :unsure:
    Cheers for any input.
  2. Ian H
    Ian H
    14 Sep 2010
    5,919
    Thanks Received:
    647
    Rochdale
    Country:
    Make your opening into the house or climb in through a window opening?
  3. Sponsored Links
  4. acurachris
    acurachris
    19 Jan 2006
    301
    Thanks Received:
    58
    Manchester
    Country:
    I did think about making the opening in the house although it's bang in the middle of two bedrooms at the minute and then i'd have to go through the house all the time.
    I suppose the obvious option is the window, it's just whether it will cause issues when the scaffold goes up the next lift; maybe i'm overthinking it (i'm good at that). Climbing through a window with a bucket of mortar, blocks, tools. Having said that, a hole in the floor with joists at 400mm centres isn't going to leave a lot room either... i'm not as slim as I once was! :whistle:
    • Like Like x 1
  5. Ian H
    Ian H
    14 Sep 2010
    5,919
    Thanks Received:
    647
    Rochdale
    Country:
    I climbed through a small opening on ours because I was too much of a pussy to go up the ladder with the stuff :LOL::LOL:
    Top left on this:
    • Like Like x 1
  6. Sponsored Links
  7. foxhole
    foxhole
    14 Mar 2006
    14,764
    Thanks Received:
    1,581
    Kent
    Country:
    Left access thru floor on mine until we knocked thru into new extension . (Floor joist trimmed and then reinstated to give 800mm wide access).
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
