Yes definitely in a cherry picker, not sure it would have helped much here?Aren't you suppose to be harnessed?
Would have probably killed him if had been wearing a harness.Yes definitely in a cherry picker, not sure it would have helped much here?
PossiblyWould have probably killed him if had been wearing a harness.
It more than likely would have catapulted him straight into the gound like one of those dog ball throwers. Plus his testicals would have caused serious injury. Only use a harness in the air so you dont fall to the ground from heightPossibly
No you also use one for driving at ground level incase you are thrown outIt more than likely would have catapulted him straight into the gound like one of those dog ball throwers. Plus his testicals would have caused serious injury. Only use a harness in the air so you dont fall to the ground from height
Nope, leave the cherry pickers to the pros. He wasn't on rough ground.No you also use one for driving at ground level incase you are thrown out
yes on rough ground you need one. To be fair it is always good to have one each time you step into one, however the reality of that doesnt happen.
