- Joined
- 28 Aug 2020
- Messages
- 1
- Reaction score
- 0
- Country
Dear sir I just bought an inflatable spa tub and it has a two pin plug and in Malta we use 3 pin plugs so I bought a 3 pin adapter with a 13 amp fuse and inserted the spa tub 2 pin plug and switched it on,everything was ok until I smelled smoke out of the wall mounted plug,the adapter melted and the spa plug melted a bit but the pi's are still solid in the plastic moulding. should I cut the 2 pin spa plug and attach a 3 pin plug instead to avoid the adapter,the spa wire is a heavy duty one.
