Add lights to circuit
9 Mar 2007
hi all, looking for some advice / possible wiring diagram to help with a small project
I'm looking to add 2 spotlights into a large built-in wardrobe in a bedroom. The room has a ceiling rose and a sible switch, I want to change to a double switch to control the lights individually
Any help would be appreciated
Thanks for the replies.
I did consider a door switch but the doors are sliding wardrobe doors and wasn't sure exactly how I would get it to work
Two switches, one for each door.
Fit the switches on the end vertical so the doors hit the switch and break the contact when the doors are closed.
Two switches, one for each door. ... Fit the switches on the end vertical so the doors hit the switch and break the contact when the doors are closed.
I'm not sure I understand - what do you mean by the 'end vertical'?
In any event, mine has three doors, the middle one of which does not come in contact with anything when the doors are 'closed' (and it has to be able slide over either of the other two)!
Kind Regards, John
Aah, maybe not the best plan then. Maybe one or two PIRs then. Depending on the size of the wardrobe
Yes, that's a possibility.
I did toy with the idea of doing something like you suggested - with 'push to break' switches at either side (and ignoring the middle door). However, that would have meant (a) that one would have to move both outer doors away from their 'parking' position (something one wouldn't normally do) in order for the light to come on and (b) that the light would not come on if (as is often the case) one just moved the middle door to one side.
The somewhat more complicated method I ended up involved magnetic (reed switch) 'burglar alarm' sensors on each of the doors, wired in series and operating the light via a relay. That means that I have to have a little ELV PSU running all the time, but it does mean that the light comes on if one or more of the doors is moved from it's 'parking' position - and it's worked fine for 25+ years.
Kind Regards, John
