There is an in-line cable switch where the cable emerges from the bracket for isolation/replacement.Crafty said:how do you intend to isolate the TV quickly?
Whats happens when you need to replace the TV or decide you dont like it there?
stevesey said:You have now - wall mounted 14in portable 18in below ceiling height, buried cable + aerial to loft where there is a 3A FCU from the lighting circuit (fed by 6A Type B MCB). All no problem with fuses or tripping. As it's hard wired to the FCU so there isn't a 13A socket that could be abused in future.eddie current said:the post quite clearly states that the socket is for a tv.
1 - not for an amp in an attic and
2 - 3 amp spur unsuitable for a tv
i'll re-phrase myself. i've never heard of anyone powering their television set off a lighting circuit!
Have it at the back of my mind to put spur off the ring up through the airing cupboard at some point - as this would be the "proper" way of doing it.
eddie current said:unheard of to install a socket off a lighting circuit.
Toaster? or death trap??RF Lighting said:This toaster also plugs straight into the lighting circuit
Useful for v.thick sliced breadCrafty said:Toaster? or death trap??RF Lighting said:This toaster also plugs straight into the lighting circuit
eddie current said:where did you find those lol?
the antiques roadshow?
it was probably 15th edition when they made those things!!
Crafty said:Toaster? or death trap??![]()
Not sure where I heard it, but to repeat a comment someone once made to me...it uses one of the methods of protection against direct contact that BS7671 doesn't recognise "left looking so obviously dodgy that no one of sane mind would touch it, so its actually reasonably safe!"
