I'd like to add a radiator in a small ensuite. On inspection, there is clearly a spare 'way' on each of the flow and return manifolds, with a stop end (obvs) in each. It's 10mm Hep2O pipe into compression fittings into copper/brass manifolds. It's 25 years old, with no issues so far. And easily accessed too.
Is it simply...
1. Run Pipes to site from manifold
2. Drain
3. Connect each end
4. refill using fill loop,
5. Bleed all rads.
Have I missed anything? Any other advice welcome.
Cheers
CG
Is it simply...
2. Drain
3. Connect each end
5. Bleed all rads.
Cheers
CG
