I am in the process of adding two new radiators. my central heating is in micro bore (10mm) (pumped off a header tank)
I have found the 'source' the 22mm pipes where all the micro bores T into.
just a few questions to put out;
When I T into the 22 pipes can i use 15mm pipe instead of the 10mm used to feed the other radiators?
Can i then T off this 15mm pipe to feed another rad or do i need to go back to the source?
Any comments and advice welcome
cheers
phil
cheers
phil
