Adding a spur to a socket.
29 May 2013
Lancashire
Hi I want to spur off the current double socket in the study room, at the moment I have checked there is two wires coming into the socket does this mean I can add a spur? Also is it possible to extend the current double socket and then add the spur ( would only do this if I was to move the computer to the other side of the room )
Thanks.
Not necessarily.
You must confirm that it IS a ring (or a radial) and not a spur off the ring which has had a second spur connected.
I don't understand.
Right ok. It is a ring circuit and I don't think it is spurred as it is the only double socket in the room.
I meant if I move the existing double socket in the new location presumeably after that I can spur off that?
I would have to extend the wire via JB to the new location.
Thanks.
I'm not qualified to tell you any of this .
As above for checking a ring/radial.
As for "extending" do you mean moving the double? This may be possible either by tracing back the 2 cables and replacing with new longer ones to the new position, or less preferably by using connectors in the current backbox to connect a new pair of cables to the new position. You would have to place a blanking face on the current double to make sure the connection was maintainable.
If you do move the socket (or even if you don't) it may be preferable to extend the ring rather than adding a spur and since you will probably have boards up etc it's probably just as easy.
It's probably a ring.
But do you know if it's a properly functioning one, with correct continuity on all 3 conductors?
It's probably not a spur.
But you do need to check.
As per above comment - if you're doing that, why not simply extend the ring to the new locations?
Also, is the existing circuit RCD protected?
Please read this: http://www.diynot.com/wiki/electrics:walls
Yes it is functioning properly, continuty is there in all three conductors. I only want to add one extra socket. How would I go about extending the ring? Just to confirm there are two cables going into the existing socket.
Yes it is RCD protected.
Wise move, he'll have it fitted before this post ends..............
Regards,
Lxboy
