Adding extra light - what are the limits to DIY?
11 Feb 2017
I have a small utility area that has a single ceiling light. I want to turn this into a spot (currently a pendant) and add a second spot off it, keeping original switch. I have a builder here who wants to plaster the ceiling and my current electrician is out of action for the moment. Does anyone know if this is permitted works by myself? I seem to remember something about minor modifications and wondering if this is small enough (just linking an extra spot) would be ok?
Thanks!
It varies through the UK what you can do without registering the work, you can do any work in the house, there is nothing you can't do, but some work needs registering with local authority and the cost at in Wales £100 plus vat for first £1000 worth of work means often cheaper to use a scheme member electrician who can register the work far cheaper.
In England very little needs registering, work in bathrooms, new consumer unit and new circuits, in Wales it also includes work outside, and kitchens, the rules were relaxed after the Welsh parliament got control so we are still using the original English rules.
However it does not matter if it needs registering or not, it should still follow BS 7671 current at the time of design, so you should complete a Minor Works certificate, and in the main DIY people don't have the equipment or skill to complete the certificates, so if your work caused some one to be injured you can still end up in court, but there is nothing stopping you from doing any electrical work in the home.
For rented property you need an EICR (electrical installation condition report) or a Minor Works or an Installation certificate to cover all electrical work again varies through the UK, so with rented property you need that paper trail, owner occupied your unlikely to have anyone wanting to view it, so one can get away with not doing the work to the standard required by British Standards, if this was not the case, there would be little point in this forum.
BS 7671 has been undated over the years, and the home must comply with the one in force at the time of design, if you alter the design then it has to comply with the current BS 7671, so if you swap a ceiling rose for a lighting bar with multi lights, you need to decide has that altered the design? If so then it needs to be RCD protected where maybe before the date of design did not require it.
Note it is design not installation date, so where design not changed then still on old BS 7671.
Please remember you have asked if permitted, so you may drive a car with a trailer at 60 MPH on normal roads without the speed cameras catching you for speeding, but the permitted speed is 50 MPH, so we all likely at some point break laws and regulations and get away with it.
So I would fit lights to my own home without worrying about minor works and the like, but that does not mean it is permitted.
In short, press on mate. Just do the work safely.
Your pendant probably is a connection point that has several cables. You need to reterminate these properly as the junction will now be up in the ceiling. Suggest you use a maintenance free junction box.
The existing ceiling rose is NOT suitable.
Thanks - I normally use the old round junction boxes with screws but will look at maintenance free - the wagoboxes seem popular
The round ones aren’t really suitable s as my more. Firstly try are designed to be screwed to something (like a joist) there is no cable restraint do they didn’t be “floating”.
if they are secured, then they won’t be accessible, and screwed terminals now have to be accessible.
Wagos is an option. To make the junction MF compliant you’d need Wago connectors plus a Wago box.
