adding new radiator
30 Nov 2004
we wish to add a new radiator. Is it possible to run the new radiator straight of the pipes that come out of the combi boiler?
as has been said yes
just dont cut the gas pipe or the hot/cold water supply
ill try not to lol:), can u run microbore of 22mm pipe or do u need to go 22 mm - 15 mm - microbore?
you can run mircobore FROM 22 ( i take it thats what you meant?)depending on length of run and how many rads you are going to supply
thanks, its just going to be one rad and the pipe would run for about 3.5 meters, i take it this distance is not to great?
if all the pipe work is being run behind kitchen base units is it worth just running 15 mm pipe?, am i correct in thinking that the would be enough clearance behind base units?
If the work will be hidden behind units I would suggest using Hep 2o pipe & fittings (plastic tube & pushfit connections) Easy, peasy etc.
