Adding smoke alarms to lighting, replacing junction box
I apologise - I have linked to the incorrect product above but the one I have previously used has a permanent supply (L&N) in and a permanent supply out (L&N) - hence you can chain multiple boxes together.
https://www.screwfix.com/p/surewire-sw4l-mf-16a-4-way-pre-wired-junction-box-white/2742j
The product above then has 4 switch connections and 4 corresponding light connections. This is the SW4L-MF and the wiring schematic is explained here: https://www.surewire.co.uk/products/light-and-switch-junction-boxes/products-and-benefits/
The one I previously linked to had one switch to operate all lights and I suppose is more suited to multiple downlights in one room.
That one looks perfect. I was just about to shell out on a big box of wago connectors that I might never use again.
Thanks so much for your help guys!
