Hi
I'm about to start my first tiling job and just want to be sure I've eveythign boxed off.
The tiles are 8mm ceramic wall tiles 300mm x 300mm and won't be exposed to more water than splashes. The walls have been recently skimmed and the area of the tiles has had a mist coat but i will scrape down before starting. The walls are solid walls apart from one small side which is the back of a partition wall for sliding wardrobes.
I assumed no special adhesive but I'm thinking flexible due to the possible movement on the partition wall when the wardrobes are opened and closed against the wall. I will buy ready mixed as it's my first time I'm not confident to get the consistency correct.
Also, when applying the trowel lines should the teeth touch the wall or a thin layer of adhesive still be in the lines?
Thanks.
Thanks.
