Whatever the protective measure is instead of ADS?![]()
...for example a system not protected RCD with rewireabke fuses. What would the protection against electric shock be. ?
that would be the "EEB" part that they've removed now..
prolific earthing of everything that's metal and could become live in the event of a fault..
basic insulation of live parts...
etc..
if you're stupid enough to take the front off a busbar chamber and grab an un-insulated busbar that's "protected" with a 200A fuse ( or breaker for that matter ), then you're going to get a hefty, and very likely fatal, shock...
Reminds me with an arguament I had with an assessor - he tried to tell me it would be more fatal to touch a 1000A busbar than the wiring in a light switch. I told him that owing to the amount of current which is required to kill (about 0.1A) you it didn't really matter where in the system you touched metal!if you're stupid enough to take the front off a busbar chamber and grab an un-insulated busbar that's "protected" with a 200A fuse ( or breaker for that matter ), then you're going to get a hefty, and very likely fatal, shock...
