Advice needed regarding staining veneered MDF
1 Jan 2010
London
Hi All,
I want to replace the drawer and door fronts of our bathroom vanity unit and can order some pre-cut veneered MDF. I'm looking for a dark walnut / oak but unfortunately the darkest walnut veneered MDF I've found is too light. Can I stain this or should I order oak veneered instead and stain that. I'll then be adding a matt coat of varnish / lacquer to add some moisture protection.
Daz
Links to the possible veneered doors might help. Do you mean flat veneered door without any moldings?
looks like around about £80-110 for a drawer front and a door is that what you expect ??
I did contemplate buying veneer and cut MDF then sticking the veneer on myself but I've not done it before, nor do I know how to trim the veneer off so would more than likely end up making a mess!
think it'll cost around £200 all in for the veneered panels cut to size.
A 1220mm x 2440mm sheet of 19mm Oak Veneered MDF is anything from £80 to £120.
It then has to be cut to size and edged with iron on oak veneer edging about £25 for £50metre roll, so £200 all in for your panels is a good price.
Osmo Top Oil and such like are safe for bathrooms and veneered surfaces.
My bathroom door as for all the doors in my house are Oak Veneered finished with Osmo Top Oil, the bathroom one hasn't been affected by steam condensation water etc.
We'll be moving next year so this is also just to polish up the bathroom a bit as it hasn't been done for years. As the walnut isn't dark enough am I better with either walnut or oak then adding a stain followed by a lacquer or oil?
