our first floor shower pipe work runs under shower then under the floor and connects to the sink pipe work in the same bathroom, then the pipe work travels into the floor, down the inside wall (but it is boxed in) to downstairs and runs out of the house, it’s PCV piping and there’s a few 90 degree joints and junctions.
At the moment water is running very slowly, I think that the pipe work between the shower and sink is clear, it’s the pipe work past this point that’s semi blocked.
I have blocked the sink plug (and overflow) filled the shower tray (easy todo when it’s not draining correctly) and gone at it with a plunger. First off a load of crappy stinky gunk came up, lots of it, this was then vacuumed up with our wet/dry vac. Then….lots of grit came up, I think it might be limescale. Again we vacuumed this up so it didn’t go back down the drain.
But this has not solved the issue.
From there we got some drain unblocked but that did nothing. I suspect because it is technically draining so any unblocked is simply draining away and does nothing.
My next idea (and I’ve not tried this yet, tell me if this is a good/bad idea) is to cap off the outlet and full the whole pipe work with some form of limescale remover or chemical unblocked and let that soak for a few hours.
Sadly because the pipe work goes though the floor and is boxed in downstairs it’s not practice to get access to it directly.
Anyone have any idea or tips?
