- Joined
- 18 Sep 2017
- Messages
- 103
- Reaction score
- 0
- Country
If you don't want an RCD, then it is possible.
The kiln would be permanently wired to an isolator switch, and the cable for the circuit from the consumer unit will have to be installed using a method which does not require an RCD.
That also avoids the use of an interlocked 16A socket & plug, which will be far more expensive than a fixed wiring connection.
Had 2 guys come around and that was his solution ie isolator switch and hard wired into that (option 1)
The other guy suggested fitting some device to the consumer board. Some type of box with an isolator and running from that. This second option was more expensive.
I assume option 1 is just as safe
