    Dismiss Notice
Advice on adding a timer/thermostat to my BoilerMate system
Discussion in 'Plumbing and Central Heating' started by 1jobdone, 10 Sep 2016.
  1. 1jobdone
    1jobdone
    22 Aug 2012
    2
    Thanks Received:
    Stirlingshire
    Country:
    Hi there,
    I'm looking for advice : ) I have a BoilerMate 2000 and Maxi boiler in the garage. I have an old Potterton thermostat control on the wall in my hall. We are about to decorate and want to replace the Potterton thermostat and move it upstairs to better regulate the temperature upstairs as it gets very warm upstairs.
    My wife recently asked our local heating engineer about replacing the existing thermostat with a wireless thermostat with a timer function. We could then keep it upstairs. Our heating engineer said that it's not possible as you can't use a timer to control the heating with a BoilerMate system.
    Is this correct? It doesn't seem right to me as surely we would just be adding different temperature/time settings to a thermostat. But then again, I'm not a heating engineer : )
    Just after some advice from others with more knowledge than myself.
    All the Best
    Byron
  2. Sponsored Links
  3. McCombi
    McCombi
    9 Jun 2012
    2,508
    Thanks Received:
    614
    Aberdeenshire
    Country:
    Can't see why not.
    Boiler mates work under principle store is always hot and when there's a heating demand, a switch is made and sends power to heating pump to circulate around radiators so can't see why a wireless thermostat won't do the same job in activating the pump via a relay.
  4. petit_pablo
    petit_pablo
    18 Nov 2007
    9,068
    Thanks Received:
    1,808
    Lincolnshire
    Country:
    Easily doable.
    There's a connection for a thermostat on the boilermate PCB, your existing stat will be wired to there. Use this and a perm L-N-E to power the receiver. Put a programmable stat where ever you like.
    The built in timer either needs linking out or leaving on constant.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
