- Joined
- 9 Dec 2008
- Messages
- 34
- Reaction score
- 0
- Country
Hi All,
I have a Gardtec 816 home alarm, which sits in my shoe cupboard.
I had an issue with it some time back where, because it was in the shoe cupboard, it had the front panel knocked off it (the alarm motherboard where the battery is not the keypad) by a large pair of boots being flung in and the the keypad started beeping constantly.
Due to Covid we are always in and didn't use it anyway.
Naturally i have my user codes but not the engineer codes for it.
Its not under contract but the company who used to look after it from a previous home owner wanted stupid money just to come and look at it, IIRC it was in the region of £175 plus £50 for every extra 15 mins he was there after 45 mins or something. So possibly cheaper to get a new one at that point.
So i opened the keypad and disconnected the wire to the beeper so the keypad shows a tamper alarm for that but it stopped the buzzer going off in the keypad - silence!
A few months later however, i read, somewhere, that if there is a power cut that it may trigger the bell to go off as the motherboard still has power and the battery connected. Is that correct?
At this stage i just want to turn it off, i have found a place on ebay which apparently will reflash the motherboard bios to remove /reset any codes for about £25 and i may do that and try to set it all up again - a small project for me
So firstly, if there is a power cut would this cause issues as i may just forget about it if not?
If it could and i wanted to disable it completely, would it be best to remove the connections to the bell then the battery then the power or is there a better method to avoid annoying the neighbours?
