Advice required - demolishing a garden wall.
24 Sep 2004
London
I am currently considering the prospect of demolishing a 2m high, half brick garden wall. The wall currently acts a divider between my back garden and a portion of my front garden that runs up the side of my end of terrace house. Its removal will create a single larger back garden which I plan on turfing to create a lawn area. Demolishing the wall shouldn't be a problem but I will be left with the footings which no doubt will cause me a headache.
Has anyone had experience of removing old footings? Is it a diy job and if so what techniques shoud be used? I'm assuming that it would be best practice to remove the entire footing - let me know if I'm wrong.
Thanks in advance for your advice and or suggestions.
If it's an old terrace it will just be brick below ground level.
Why remove the wall? You'll end up with a bland and ordinary garden .
joe
Hi Joe-90. Thanks for your post. The wall was built in the early 1970's. The garden will remain a walled garden as I will be applying for planning permission to build another wall closer to my boundary. The end result is that my back garden will be approx 3m wider.
why remove the foundation? just bury it
you say you want to build a new wall closer to property boundary, what is on the other side of the boundary (ie road etc)?
other things to keep in mind
your only generaly allowed 1m high walls in the front garden and simmilar hight can apply on side walls ajoining busy roads
best check with your local council planning office
