- Joined
- 7 Jan 2011
- Messages
- 182
- Reaction score
- 25
- Country
Hi all,
have been lurking here a while and responded to a couple of topics, i think i have my situation covered but i just need some clarification.
Tiles for the walls and floor are 600mmx400mmx10mm Porcelain. Weight approx 28Kg sqm with addy and grout, i plan on using a rapidset flexi adhesive and grout, probably Granfix as i have used it before. Oh and i have a wet cutter and diamond bladed angle grinder for cuts.
I am completely redoing my bathroom, stud walls being built around the shower bath to conceal the shower valve and wall mounted taps. I plan to clad this with 12.5mm Aquapanel. This will take 50Kg sqm weight, according to BNQ website.
For the floor, currently i have floorboards, most are bowed and the edge boards seem slightly higher than the rest, they are however solid and there is no deflection in the floor so do i:-
1. Overboard with 15mm Ply, my concern with this is the bowing and the uneven edges, could cause lippage in the tiles if i cannot get it down completely flat
2. Overboard with Aquapanel or Marmox boards, secured with flexi addy, taped and screwed down.
3. Rip the lot up, add extra noggins and put down 25mm Ply, back and edges treated with SBR acrylic primer.
Plan to redo heating pipework anyway, and add a towel rail, so some of the boards will need to come up,
So i guess the question is have i missed anything, is option 3 for the floor the best one, and have i got the bath/shower area covered?
