The top connection IS the vent fitting. Where does your cold feed connect to your system? There is no provision for feed connection on that separator.
Run 22mm up and over the exp tank leaving the correct amount of dry vent.
See your boilers instructions for that. What reason do you have for fitting it?
No you can't is the quick easy answer. An aav could easily fail closed, they are not designed as a saftey device.
Nads, I do wish you would have disclosed ALL the relevant info at the start. It saves a lot of confusion.
Pertinent information to elaborate on the function of a piece of hardware?Perhaps it's best to let the experts decide what is or isn't pertinent information?
When was I being a smart a7se? Why do you think I am asking questions? I don't pretend to know everything, that is why I am researching what I need. I have an unusual problem that requires me to ask other people for their knowledge. Isn't that what this place is for?Trying to be a smart a7se could have left you with a dangerous installation.
