Hi
The Airflow icon 15L fan in my bathroom is not working, it has previously worked ok, but now nothing is happening at all.
It is connected up so when the light is turned on the fan comes on, there is also an isolater switch outside where you can switch this off and on if you dont want it to come on with the lights.
The lights work fine
I tried a quick test but not sure if this would work, I opend the unit up and disconnected the feed, I then conected this to a plug with a long lead and plugged it into the mains to bypass the isolater and cabling. Nothing happened I presume the unit has packed in on this test, then I thought is this the correct way to check if its working? I think the plug has a 13A fuse should I have used 3A in the plug, also does it need the isolater switch hooked up in order for it to work?
Any ifo would be great, dont want to buy a new one at £50 to find out its something else
