- Joined
- 16 May 2016
- Messages
- 7
- Reaction score
- 0
- Country
Hi All,
I have a wired alarm system in the house which was working absolutely fine until recently but one of the PIRs has appeared to die and as a result the alarm won't arm unless I omit the area.
Two PIRs are wired to Zone 3 in the control panel and oddly The one at the back of the room works but the other at the front of the room is dead. I've purchased a new PIR to try assuming it was that and its still dead (however the 2nd PIR still works). I've tried measuring the power with a multimeter and there's absolutely nothing there which is obviously why it's not working.
At the control box there's only one set of 6 cores wired for both sensors so would assume they are wired in series however out of the working PIR I was expecting two sets of cables - one to the alarm box and one to the other sensor but that isn't the case - both PIRs have 1 wire coming out of them. I have tried wiring the "dead" sensor directly into the control panel with a short bit of wiring to test and it bursts into life no issues.
What I don't understand is quite how the sensors are wired in series if there's only one set of wires to each PIR and secondly is there anyway of fixing the wiring given its all buried underneath the upstairs flooring and no idea whereabouts it runs? If there is no way of fixing it without lifting all the floors, is there anyway somehow of knocking the "dead" sensor out so that the single sensor could work on its own?
Many thanks
Many thanks
