Hi All,
I am considering updating my old Alarm system and had a few questions I was hoping some of you guys might be able to help with.
My current alarm system is a wired system with PIRs, bell and front door contact. It has a main panel and a wired keypad.
1) In upgrading it, I was hoping I could reuse the existing wiring for the PIRs - I assume this is possible and the wiring for PIRs has not changed in the last 30 years eg number of wires to be connected etc?
2) Also, will I be able to reuse the existing bell or will I need a new one but be able to use existing wiring ?
3) I am also assuming the front door contact needs to be a new one, compatible with the new alarm system ?
The new system should be able to support both wired and wireless as I would like to extend the current wired system with additional PIRs and door/window contacts. I don't want to run additional wires for these so would like the new sensors to be wireless.
OK, based on the above, I quite like the sound of the Pyronix Enforcer range. In particular its smartphone app so I can monitor the system when away and the option to add in compatible CCTV cameras.
4) Is there a specific Pyronix model that would do all the above ie mix wired with wireless and include Home Control app and extendable with CCTV ?
Worth noting I plan on replacing/installing the system myself. I do have some very old experience installing commercial alarm systems but have forgotten everything !
Thanks in advance for your help.
