Alpha ETEC Boiler no pressure
7 Nov 2008
Hamilton, Lanarkshire
Hello,
I am hoping someone can help me. I have just had a new ETEC 28/33 boiler installed. The pressure has gone down to zero and the filling loops aren't doing anything when turned. The radiators had to be bled and a lot of water came out.
Would anyone know how to fix this please?
Thank you.
Kris
This is a diagram of the two taps I think are the filling loops
If its the circled bits ,they are isolation valves ,not what you need.
P.s the pics short of detail.
I am not overly f
amiliar with your boiler model ,but I think you have an external filling loop. Look for a braided ,silver coloured flexible hose. Or post a pic of pipework below your boiler.
your boiler does not have an internal filling loop, dont touch the valves that you have circled, follow the cold water inlet pipe and you will see a silver (usually) hose between that pipe and the CH return , you need to open these valves until the pressure reaches 1.5 Bar, then close them again
Thank you everyone for your help. The filling loop was quite a bit away from the boiler, but I found it thanks to your great help. Much appreciated.
Now I need to figure out the damn Salus boiler receiver and thermostat. It won't switch the heating off now!
These are terrible for losing connection, try turning the thermostat manually all the way down and then all the way back up and see if they start talking to each other, if that fails you will have to manually re-bind them loads of videos on youtube how you do that
not a hard thing to do once you know how , have to say not the most reliable of controls
Managed to get the flame symbol back on the thermostat, but the temperature keeps going up past the desired amount and the flame symbol goes off. There is a red light on the reciever within the bouler. I have tried switching it off, switching the power off at the mains, taking the battery out of the thermostat, but no success.
