Always on Radiator
23 Mar 2005
I have an open vented pumped central heating system with one radiator that is "always on" in the bathroom irrespective of the central hearting pump.
I have replaced the "always on" standard radiator for a chrome towel rail type and moved to an adjacent wall. The chrome towel rail type is around twice as high as the one it replaces.
When I bleed the system the radiator stays "always on" for around 1 day and then goes permanently cold.
Is the problem due to the height of the chrome towel rail radiator or could it be something else.
Thanks for your help. :cry:
The old radiator was "always on", I believe this is the way it was designed.
All I did was remove the old radiator, cut the pipes and extend them to the new chrome towel rail type radiator.
To tell you the truth I dilled two holes in a joist lower down from the pipes original level and passed the pipes through them, then fed them up to the rad valves,
So I guess the pipes drop down from their original level then rise up to the rad.
I thought it would be a better place for the pipes than just under the floorboard.
