Anchoring a Safe to dry lined wall
5 Jul 2006
Yorkshire
Hello folks. I've done some searching on here to try and get an answer first so as not to be repetitive but can't find the answer.
My house is the usual breeze internal walks and dot n dab plasterboard.
I have a hell of a job securing anything substantial to the walls. I have used the expanding sleeved type bolt fasteners before but they struggle to grip, spin in the holes or just pull out.
I am fitting a safe this weekend which I want to bolt to floor and wall. Although one bloke would struggle to lift it I would still like to do a solid job of bolting it up.
Can anyone recommend a method for my type of wall. I'm told there is a type of bond to anchor bolts into or is there a better anchor fastener on the market
Any help would be appreciated
Thunderbolts will do the trick, but don't over tighten as could break the board.
Alternative would be to cut the section of board out and fit directly to block-work.
Go through the wall with a plate t'uther side.
Then plaster over it.
Or put a safe in front of it.
Or just have a dummy safe.
build a brick wall round it.
aswell as bolts to the floor,if your sure you dont EVER want to remove it,use something like gripfil and beg the bugger down. :wink:
