another bathroom extractor fan puzzle
30 Jul 2011
Oxford
apologies, i've had a rummage through a lot of the older extractor fan posts but couldn't find what i was after (possibly because i was blinded by jargon more than once)
my old extractor fan died so i decided to replace it. it switched on with the light switch and stayed on for a while after the light was switched off. i bought a new 'extractor fan with timer' from wickes, assuming this to be more or less the same thing.
here is a photo of what i was faced upon removing the casing from the old extractor fan:
click here for picture
now i'm going for the brown being Live, the black with blue tape being Neutral and the yellow/green being earth, right?
the new fan has three terminals, L, N and L1.
i assume therefore that brown goes with L, black/blue with N but then what do i put in L1. is it the extra grey cable? if so, how come it isn't connected on the old fan?
the new one (and the old one i assume, because the earth is unconnected) is double insulated btw.
thanks in advance if you can help me :)
If that is a 230V fan, it only has L&N connections, so there is no way it could stay on after the light is switched off.
The other grey wire MAY be a switched line, assuming it is connected at the other end. You need to locate the other end of the cable and see what is connected where.
The old fan in its present format doesn't appear to be a timer fan.
The photo is a bit dark but you have the brown (switched live???) and black(blue sleeve - neutral???) going into the terminal block with the two red wires leaving and going one assumes to the motor. The second terminal strip appears to be floating and contains a earth wire and what appears to be the grey wire which may be the permanent live.
As already said you will need to trace back the cables to your light ceiling rose and establish which one is permanent live (grey?) which one is neutral (black/blue sleeve) and which one is switch live (brown ???)
One this is done wire according to the instructions.
Is it possible that the fan has a timer unit somewhere else?
Loft for example.
Loft for example.
if there is a separate one, it's not anywhere accessible. we live in a ground floor flat with no loft.
thanks for your thoughts everybody, i'll have a look in the ceiling rose tomorrow and see where that takes me.
